2851 Terminating SIP/PRI/FXS
Answered Question
Does anyone see a problem with terminating a SIP connection (PSTN), PRI(PSTN) and FXS in a 2851 router?I know it's a broad question, but any thoughts would be great.
Correct Answer by csco11063007 about 8 years 7 months ago
Yes.Supported.You can use multiple protocol on the same gateway SIP,H323,ISDN PRI,Analog PSTN,MGCP,SCCCP..
Better to configure as Unified Boarder elements(IP to IP gateway)
Please rate useful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
csco11063007 Wed, 08/20/2008 - 15:39
