CPM_VOICE_CALL_MOD_REJ received (AS5400HPX)
Aug 20th, 2008
I am getting the following errors and want to know what is the nature of this reject in Call processing.
msg_to_calls_mgmt: msg type CPM_VOICE_CALL_MOD_REJ received
from Trunk(7):Bad CID DAF(DBF)s3/p73 u2/c1 event 3
The box had CT3 in M23 configured also T1 in CAS mode with "ds0-group 0 timeslots 1-24 type e&m-fgb dtmf dnis"
POTS incoming and VoIP leg is SIP. 20% calls are failing with the above errors when debug call-mgmt ON.
AS5400HPX is mating with DMS250 in e&m wink start. Does anyone has DMS250 running configuration with AS5400?
