Extension Mobility
Answered Question
Aug 20th, 2008
Hi All,
I configured 10 user profile for EM, only one of them can log off successfully, the reset of the users can log in but when they want to log off and press service button, on the phone screen shows "to set up speed dials and other services for your phone, please go to http://......./ccmuser" and they can't log off successfully.
any suggetion would be very appreciated.
thanks
Alex
Correct Answer by Chris Deren about 8 years 7 months ago
You need to subscribe the EM service on all the Device Profiles just like you do on the phones.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Wed, 08/20/2008 - 16:11
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
alex goshtaei Wed, 08/20/2008 - 16:24
I have another question, Chris;
when I configure speed dial and BLF buttons on the EM profile, then I login with that profile, it doesn't show speed dial and BLF buttons. any idea?
thanks
Chris Deren Wed, 08/20/2008 - 16:27
  • Hall of Fame,
Are these configured as BLF on the device profile?
Make sure you have "Subscribe Calling Search" space specified on the device profile as well.
Chris
alex goshtaei Wed, 08/20/2008 - 16:32
yes, I configure BLF buttons on the profile but I don't see "subs calling search" in device profile. I am using version 6.1
a.namnami Thu, 08/21/2008 - 02:31
The "SUBSCRIBE Calling Search Space" should be configured on the phones where the users log on. The "SUBSCRIBE Calling Search Space" must contain the UDP DN's Partition (most common internal partition).
Hope this can help :)
Best
/AN
Rob Huffman Wed, 08/20/2008 - 16:16
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Alex,
On the other (non-working) extensions is the Logout Service configured?
Rob
