sh arp: cplane 127.0.2.1 0000.0002.0001
Answered Question
Aug 20th, 2008
On sh arp command, the firewall lists: cplane 127.0.2.1 0000.0002.0001
What is the interpretation of the above?
Thanks.
Correct Answer by Farrukh Haroon about 8 years 5 months ago
This is internally used by the ASA. You need not worry about it. You will find many such things. Check show asp ... interface for example.
Farrukh
Overall Rating: 5 (1 ratings)
Correct Answer
Farrukh Haroon Wed, 08/20/2008 - 19:00
Farrukh
