3640 Terminal Server
Answered Question
Aug 20th, 2008
  • Blue, 1500 points or more
Hello:
I never knew a Cisco 3640 router can act as a terminal server. I am confused.
When I telnet to this terminal server device in the lab, this is the configuration I see.
testlab#sh run
Building configuration...
Current configuration : 3726 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname testlab
enable password
ip subnet-zero
interface BRI0/0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0/0
ip address 10.36.250.22 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.36.250.250
ip http server
menu testlabTS title ^CCCCCC
You are currently logged into the ACS Tarrytown testLAB Terminal
^C
menu testlabTS text 1 Press 1 to console into R1
menu testlabTS command 1 telnet 10.36.250.22 2033
menu testlabTS text 2 Press 2 to console into R2
menu testlabTS command 2 telnet 10.36.250.22 2034
menu testlabTS text 3 Press 3 to console into R3
menu testlabTS command 3 telnet 10.36.250.22 2035
menu testlabTS text 4 Press 4 to console into R4
menu testlabTS command 4 telnet 10.36.250.22 2036
menu testlabTS text 5 Press 5 to console into R5
menu testlabTS command 5 telnet 10.36.250.22 2037
menu testlabTS text 6 Press 6 to console into R6
menu testlabTS command 6 telnet 10.36.250.22 2038
menu testlabTS text 7 Press 7 to console into Frame Cloud
menu testlabTS command 7 telnet 10.36.250.22 2039
menu testlabTS text 8 Press 8 to console into BGP1
menu testlabTS command 8 telnet 10.36.250.22 2040
menu testlabTS text 9 Press 9 to console into BGP2
menu testlabTS command 9 telnet 10.36.250.22 2056
menu testlabTS text 10 Press 10 to console into SW1 (3750)
menu testlabTS command 10 telnet 10.36.250.22 2041
menu testlabTS text 11 Press 11 to console into SW2 (3550)
menu testlabTS command 11 telnet 10.36.250.22 2042
menu testlabTS text 12 Press 12 to console into SW3 (3750)
menu testlabTS command 12 telnet 10.36.250.22 2043
menu testlabTS text 13 Press 13 to console into SW4 (3550)
menu testlabTS command 13 telnet 10.36.250.22 2044
menu testlabTS text 14 Press 14 to console into cable1/5 (not connected)
menu testlabTS command 14 telnet 10.36.250.22 2045
menu testlabTS text 15 Press 15 to console into cable1/6 (not connected)
menu testlabTS command 15 telnet 10.36.250.22 2046
menu testlabTS text 16 Press 16 to console into cable1/7 (not connected)
menu testlabTS command 16 telnet 10.36.250.22 2047
menu testlabTS text 17 Press 17 to console into cable1/8 (not connected)
menu testlabTS command 17 telnet 10.36.250.22 2048
menu testlabTS text 18 Press 18 to console into cable2/1 MOJEF301-WR01
menu testlabTS command 18 telnet 10.36.250.22 2049
menu testlabTS text 19 Press 19 to console into cable2/2 NJLEO2CH-WR01
menu testlabTS command 19 telnet 10.36.250.22 2050
menu testlabTS text 20 Press 20 to console into Louisiana-FW01
menu testlabTS command 20 telnet 10.36.250.22 2051
menu testlabTS text X Press X to exit the menu
menu testlabTS command X menu-exit
menu testlabTS clear-screen
alias exec mt menu testlabTS
line con 0
line 33 64
session-timeout 20
flush-at-activation
no exec
transport input telnet
transport output telnet
autohangup
line aux 0
no exec
transport input all
line vty 0 4
password
login
autocommand menu testlabTS
line vty 5 15
password
login
end
testlab#
I do remember the old Cisco 2511s that had a dozen or so ASYNC ports to which you would connect the console ports of the devices you want to access remotely.
I dont see any such interfaces on this 3640.
Any thoughts?
Correct Answer by Edison Ortiz about 8 years 10 months ago
I am trying to find a link to a Cisco page that will explain that configuration above. I mean the "menu......" jazz that dictates what the output is that the user will see when telneting to the box.
See:
http://www.cisco.com/en/US/docs/ios/fundamentals/configuration/guide/cf_connections_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1001601
Overall Rating: 5 (2 ratings)
Edison Ortiz Wed, 08/20/2008 - 17:42
  • Hall of Fame,
    Founding Member
Victor,
This portion is the terminal server connection:
line 33 64
session-timeout 20
flush-at-activation
no exec
autohangup
Here is more information on Terminal Server on 3600 Series router:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00801ca70b.shtml
HTH,
__
Edison.
lamav Wed, 08/20/2008 - 18:40
Edison:
Thank you very much, my friend. That helps a lot. I see then that the 3640 is using an NM32A virtual ASYNC module that uses a high density connector cable with RJ-45s on the other end ( a spider cable, as we used to call them). Got it.
Victor
Correct Answer
Edison Ortiz Wed, 08/20/2008 - 19:06
  • Hall of Fame,
    Founding Member
See:
lamav Wed, 08/20/2008 - 20:00
Thanks, Edison!
I couldnt find this link if my life depended on it! lol
VL
