Switch IP not seen by cdp neighbors detail
Answered Question
Aug 20th, 2008
Hi All
I have my switch in vtp transparent mode, created vlan's and a vlan Interface
Now, when i do a CDP neighbors detail from
I see my switch but no IP
Entry address(es):
IP address:
I neighter can ping the switch from the neighbor.
Here a part of my config:
vlan internal allocation policy ascending
vlan 115
name LD-VLAN-Management
interface GigabitEthernet0/25
description Glas to Zuerich
switchport trunk native vlan 115
switchport trunk allowed vlan 115,868,869
switchport mode trunk
macro description cisco-switch
auto qos voip trust
spanning-tree link-type point-to-point
interface Vlan115
description Management VLAN
ip address
How can i get this to work.
I don't want my neighbor to have learn my VLAN's
This is a Production-switch, i can't just play around!
Who can help me?
Overall Rating: 4 (1 ratings)
massimiliano.se... Wed, 08/20/2008 - 22:51
The native VLAN is the same on other lik? That is on the other switch (the switch which is attached to "transparent-switch"), is the vlan native the same?
Best regards.
Willem de Groot Wed, 08/20/2008 - 22:58
Hi Massimiliano
Yes, the native vlan on the other site is the same.
The trunk is up and running.
There is lots of traffic flowing even on different vlan's (868 and 869), transport works fine, just can't see the IP.
So i can't get remote on this switch,
Can't ping it.
massimiliano.se... Wed, 08/20/2008 - 23:05
From that you're sayng the layer 2 connectivity is good. A problem might be layer3 connectivity....the subnet mask of the vlan is the same on the two switches?
Willem de Groot Thu, 08/21/2008 - 06:11
Hi All
Thanks for the feedbacks!
"the Nativ Vlan should be same and the Mgmt Vlan should have been given the IP address means vlan 1" brought me on the point.
Looking at my config, i allowed only vlan 115,868 and 869 NOT vlan 1 !!
Also i had vlan 115 as native vlan, on the other end there was no such statement, so vlan 1 was native there.
Thanks all
