Voice Translation rule query
Answered Question
Aug 20th, 2008
Can voice translation rules be configured on both MGCP & H.323 gateways? Or is there some protocol-based restriction?
Correct Answer by dezoconnor about 8 years 5 months ago
As above, dial-peers won't work on an MGCP gateway as all call intelligence resides on the callmanager in this setup. If you're MGCP gateway is configured for SRST then yes you'll dial-peers.
Correct Answer by Ayodeji Okanlawon about 8 years 5 months ago
Nope. MGCP uses centralized dial-plan which all resides in CCM.
You do not use Dial-peers with MGCP
Overall Rating: 5 (3 ratings)
singh-ashok Thu, 08/14/2008 - 13:26
Thanks a lot Darren. This is what was puzzling me. I had seen dial-peers on an MGCP gateway once. Now I do recall that the router was configured for SRST too.
Have a nice day.
Ashok.
Ayodeji Okanlawon Thu, 08/21/2008 - 00:32
Its not going to work on MGCP. Because MGCP pots ports in under callmanager control, any rule defined is ignored. So you can only use it with H.323.
HTH, pls rate useful posts
singh-ashok Thu, 08/21/2008 - 00:49
Thanks Deji,
On more query. Can you configure dial-peers on MGCP gateways ?
Ashok.
Correct Answer
Ayodeji Okanlawon Thu, 08/21/2008 - 00:52
Correct Answer
dezoconnor Thu, 08/21/2008 - 00:53
