Amin Shaikh Thu, 08/21/2008 - 00:53
Thanks.
How could I reset ACS admin password if the ACS is not running on appliance.
massimiliano.se... Thu, 08/21/2008 - 01:14
"In ACS versions 2.6 and later, issue the regedit command and remove the users in this location:
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco\CiscoAAA##\CSAdmin\Administrators
Under the Administrators key, see all the administrators that you have created. Delete the users and exit the registry. When you access ACS, you are not prompted for a user name and password. Once you are in the GUI, add administrators. "
Reference: http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_qanda_item09186a0080094bac.shtml
Massimiliano.
dhananjoy chowdhury Thu, 08/21/2008 - 08:14
Editing the registry will not work if the ACS server version is 4.0 or above.
You will have to reinstall.
But there a possibility, if you have not changed the default settings on the ACS server.
On the ACS server if you access the server by
http://127.0.0.1:2002 , it won't ask for username/passwd. But this is default setting.
