Wireless clients are being excluded
Aug 21st, 2008
Using WLC 4402 with lightweight access points. Some valid clients are being excluded because of an association failure.
Why is this happening and how do you remove them from the excluded list?
Scott Fella Thu, 08/21/2008 - 03:31
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
If you want to remove them manually, then you have to go to the excluded client list and remove them. If you want to, you can disable that feature in the advanced tab in the WLAN SSID. Verify the wireless profiles on the client and make sure they are not trying to connect to another ssid that is configured on the WLAN, this will also cause then to be excluded. Unless you only have one ssid configured.
Hope this helps.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807360fc.shtml#c9
g.leonard Thu, 08/21/2008 - 03:36
Hi Scott
Thanks for the reply. I have tried to remove them from the excluded client list but they remain after clicking remove?
Weird I know? Any ideas?
Gary
SJessulat_2 Thu, 08/21/2008 - 03:55
Hi Gary,
Clients get excluded for different reasons, e.g. too many authentication requests in a given time. This can be caused by a wrong username/password. Did you reenter the credentials on the affected clients?
Sebastian
Scott Fella Thu, 08/21/2008 - 07:12
  • Hall of Fame,
    2017 Wireless
Like the other post, must be bad authentication. Remove the excluded client configuration from the wlan and see if the user is able to authenticate... if not, then the device is not configured right.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
