Revision number
Answered Question
Aug 21st, 2008
Dear all,
How can i change the revision number for catalyst 4500 switch. can you tell me the commands that i needed.
best regards
thaar
Correct Answer by jaleelahmed.sd about 8 years 10 months ago
Hi Thaar,
If your both switches are belongs to one VTP domain, then you just have to configure your 4500 switch as VTP Server and domain name and connect to the network. Switch automatically loads Vlan & VTP parameters from 2950 switch (revision no also sets to 23).
Hope this helps
Correct Answer by Jon Marshall about 8 years 10 months ago
Thaar
Assuming you mean the VTP revision number it depends on what you want to achieve.
1) If you want to set the revision number back to 0 and the switch is in vtp server mode then change the vtp mode on your switch to vtp transparent and then back to vtp server.
2) If the switch is in VTP client mode and you want to update it you need to either
a) change the mode to vtp server and then make an update to the vlan database
b) more likely you need to update the switch acting as a vtp server and this will then automatically update your VTP client switch.
To update the revision number on a VTP server switch you need to make a modification to the vlan database ie. create a new vlan, modify the details of an existing vlan or delete a vlan.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Thu, 08/21/2008 - 01:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Thaar
Jon
thaar.altaiey Sat, 08/23/2008 - 22:50
Dear all,
Yes, i mean the VTP revision number, i will check what you write soon.
best regards and thanks for your help
Giuseppe Larosa Thu, 08/21/2008 - 01:25
  • Hall of Fame,
    Founding Member
Hello Thaar,
if yo mean the revision number in the sh ver it cannot be changed:
cisco WS-C4506 (MPC8540) processor (revision 4) with 524288K bytes of memory.
but if you want to clear the revision number in VTP just put the switch in another VTP domain in vtp mode transparent then back as vtp client in the correct VTP domain name.
SW-RM-SXR000-F-C4-2#sh vtp status
VTP Version : running VTP1 (VTP2 capable)
Configuration Revision : 90
Hope to help
Giuseppe
thaar.altaiey Mon, 08/25/2008 - 01:36
Dear all,
In real, i have 2 VTP server switchs. One is 4500 and the other is 2950 in my large network. After a problem occured in the network, the 4500 is reset its configuration and its revision number is set to 0, whereas the 2950 switch revision number is still 23 which is the correct one. how can change the revision number of 4500 switch to 23.
best regards and thanks for any help.
thaar
Correct Answer
jaleelahmed.sd Mon, 08/25/2008 - 02:44
Hi Thaar,
Hope this helps
Giuseppe Larosa Mon, 08/25/2008 - 12:41
  • Hall of Fame,
    Founding Member
Hello Thaar,
c4500's sh ver what configuration register value shows ?
if it is 0x2142
it is a value that makes the switch to ignore the configuration file like in a password recovery procedure.
If it so you just need to do:
get privileged access (enable)
copy startup-config running-config
and you need to change the value of the config register so it will read the config at next reload.
config t
config-register 0x2102
end
wr mem
if config-register <> 0x2412 you need to rebuild your config including VTP parameters.
Hope to help
Giuseppe
