CCIE R&S Lab
Aug 21st, 2008
  • Gold, 750 points or more
Can I use 3560G series (3560-28) switch for CCIE preperations? Also can I upgrade any 3550 switch IOS from SMI to EMI? What would you advise for access layer switches, I would like to go on CCIE Security after, so how many of switches do I need? Can I use 3550s instead 3650? What are the latest R&S official CCIE books for written and lab exams?
Overall Rating: 5 (3 ratings)
Huseyin,
The current exam blue print is:-
# Bridging and Switching
1. Frame relay
2. Catalyst configuration: VLANs, VTP, STP, MSTP, RSTP, Trunk, Etherchannel, management, features, advanced configuration, Layer 3
3. Tunneling
# IP IGP Routing
1. OSPF
2. EIGRP
3. RIPv2
4. IPv6: Addressing, RIPng, OSPFv3
5. GRE
6. ODR
7. Filtering, redistribution, summarization and other advanced features
# BGP
1. IBGP
2. EBGP
3. Filtering, redistribution, summarization, synchronization, attributes and other advanced features
# IP and IOS Features
1. IP addressing
2. DHCP
3. HSRP
4. IP services
5. IOS user interfaces
6. System management
7. NAT
8. NTP
9. SNMP
10. RMON
11. Accounting
12. SLA
# IP Multicast
1. PIM-SM, bi-directional PIM
2. MSDP
3. Multicast tools, source specific multicast
4. DVMRP
5. Anycast
# QoS
1. Quality of service solutions
2. Classification
3. Congestion management, congestion avoidance
4. Policing and shaping
5. Signaling
6. Link efficiency mechanisms
7. Modular QoS command line
# Security
1. AAA
2. Security server protocols
3. Traffic filtering and firewalls
4. Access lists
5. Routing protocols security, catalyst security
6. CBAC
7. Other security features
The Lab equipment currently is:-
* 3725 series routers - IOS 12.4 mainline - Advanced Enterprise Services
* 3825 series routers - IOS 12.4 mainline - Advanced Enterprise Services
* Catalyst 3550 series switches running IOS version 12.2 - IP Services
* Catalyst 3560 Series switches running IOS version 12.2 - Advanced IP Services
HTH>
husycisco Thu, 08/21/2008 - 09:04
Thanks Andrew, I am already aware of the Blueprint and I recheck time to time. I hope we can hear from people who prepared in his own lab an took lab exam at least once.
Edison Ortiz Fri, 08/22/2008 - 06:40
  • Hall of Fame,
    Founding Member
Yes.
Yes.
Minimum of 4.
I recommend having both. QoS is different between the 2 models, learn from both.
http://www.amazon.com/CCIE-Routing-Switching-Certification-Guide/dp/1587201968/ref=pd_bbs_sr_1?ie=UTF8&s=books&qid=1219416024&sr=8-1
HTH,
__
Edison.
sdoremus33 Fri, 08/22/2008 - 07:40
  • Bronze, 100 points or more
Edison,
I am currently using 5* 3620 and 3* 2620 combined with 2* CatOS 2900XL swtchs, will this suffuce for the CCIE Lab prep. Thanks
Edison Ortiz Fri, 08/22/2008 - 07:44
  • Hall of Fame,
    Founding Member
Replace the switches with L3 switches (3560/3750 and 3550).
__
Edison.
brandon.bennett... Fri, 08/22/2008 - 09:38
The lab uses either 3550 and/or 3560's so it is good to familiarize yourself with both lines.
3750's are identical to a 3560 except the inclusion of Stackwise.
Internetworkexpert did a comparison of the features in a 3560 and a 3550 here:
http://www.internetworkexpert.com/resources/ccie-3560-3550.htm
Most practice exams use 2-4 switches with more empahsis on the latter.
Internetworkexpert and Cisco both have a recommened book list and I highly recommend most of the books on both lists (i've read 90% of them)
http://www.internetworkexpert.com/resources/cciebooks.htm
http://www.cisco.com/web/learning/le3/ccie/rs/book_list.html
After passing the written I would find a vendor like InternetworkExpert (http://www.internetworkexpert.com) or NetMasterClass (http://www.netmasterclass.net) and get one of thier lab manuals. The lab manual will have what equipment you need to buy (or rent) in order to accomplish their practice exams.
Hope this helps and good luck!
-Brandon #19406
husycisco Thu, 08/28/2008 - 02:10
Thanks all, can you advise a specific book that you found useful before taking exam? I also need an advise about the book for lab exam too.
Edison Ortiz Thu, 08/28/2008 - 05:16
  • Hall of Fame,
    Founding Member
Huseyin,
There isn't a specific book that you can read and pass the CCIE R&S written, it's a compilation of books.
I highly recommend you read the TCP/IP Vol 1 and Vol 2 from Doyle, the BGP book from Halabi and then the comprehensive Routing and Switching Certification Guide - 3rd Edition by Odom.
Those books should cover the larger portion of the written exam.
As for the Lab, you don't get it from books but lots of rack time. Get yourself a workbook from a known vendor and allocate at least 500 hours for rack time before your lab attempt.
HTH,
__
Edison.
husycisco Tue, 09/02/2008 - 03:38
Thanks Edison, can you give some workbook examples from known vendors for lab?
Edison Ortiz Tue, 09/02/2008 - 05:04
  • Hall of Fame,
    Founding Member
I'm afraid I can't advertise a specific vendor. You need to try them for yourself. They all offer a free sample of their Labs. Try them out and see which you like the most.
The only suggestion I can give you is to search for "CCIE Workbook" in google and you will find the top workbook vendors.
HTH,
__
Edison.
