Ciscoworks Groups Issue LMS 2.6
Aug 21st, 2008
Has anyone experienced a problem with group creation, where after the group is created and populated you cannot expand the group title heading under RME\User defined groups in the group selector window? Esentially there is a minus sign beside the group name, where used to be a plus.
Joe Clarke Thu, 08/21/2008 - 07:19
This is expected if you're looking at the group under Group Administration. However, if you are in another RME application (e.g. Netconfig) then the group should be expandable provided there are devices in it.
patsull00 Thu, 08/21/2008 - 07:26
J. Hi
I realised this shortly after I posted..
Thanks for getting back though.
P.
