Unity 5 & CCM5/6 MGCP IP faxing
Answered Question
Aug 21st, 2008
Hi all,
I've read through previous postings on IP faxing but not found anything for MGCP. If customer has an MGCP gateway and wants incoming faxes delivered direct to their UM Unity what solution will do this? And does the user need a dedicated DDI?
Cheers
Rich
Correct Answer by Michael Owuor about 8 years 6 months ago
Hi Rich,
Yes, depending on the type of fax server, you may be able to integrate it with an MGCP gateway. Some fax servers such as RightFax have TDM interfaces like PRI interfaces, which you could connect in a back-to-back configuration with a PRI port on your MGCP gateway.
Hope this help.
Michael.
Overall Rating: 5 (1 ratings)
Michael Owuor Thu, 08/21/2008 - 06:02
Rich,
If your customer requires the on-ramp faxing feature, then they will have to convert their gateway from MGCP to H.323. T.37 requires specific tcl scripts which, unfortunately, are not supported with MGCP.
Hope this help.
Michael.
richb1971 Thu, 08/21/2008 - 06:04
Hi Michael,
Thanks for reply. I feared that was the case. What about using a fax server? (I really don't want to reconfigure all the gateways!)
Rich
Correct Answer
Michael Owuor Thu, 08/21/2008 - 07:07
Hi Rich,
Hope this help.
Michael.
