UCSS "User" vs DLU count - confused
Aug 21st, 2008
I understand the principle of DLU's. Different devices have different cost. Buy enough DLU's and deploy handsets as required until you run out of DLU's (as I understand it).
However, when you buy UCCS for UCM (Software upgrade protection), this appears to be listed as "per user".
Is it right that you buy the licences on a per device basis, yet you buy the software support on a per user basis ? How are the 2 linked ?
For example :
If I buy 400 DLU's to cover 100x 7941's (100x 4DLU's). 20 of those handsets may be in communal areas. So does this mean I buy an 80 user UCSS-UCM (as 80 are on users desks, with a staffing of 80).
Or am I missing something ? I thought initially that you would buy UCSS per DLU.
Any clariffication would be very much appreciated, I cannot find this specific query illustrated in cisco documentation.
Rob Huffman Thu, 08/21/2008 - 05:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alastair,
Your statement;
"Is it right that you buy the licences on a per device basis, yet you buy the software support on a per user basis?"
Is most correct :) There is no linkage between DLU's (used to License IP Phones) and UCSS which is incremented on a per "seat" basis.
UCSS:
Priced per seat, mailbox or agent based
From this good UCSS doc;
http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns165/ns737/net_presentation0900aecd8063dc83.pdf
Hope this helps!
Rob
