Fan tray 1 in high power mode
Aug 21st, 2008
I just tried to install one WS-X6708- 10GE with daughter card WS-F6700-DFC3C in a 6509 switch. Now all the 9 slots are occupied. After the installation i am getting the following logs.
Aug 21 10:21:12 DST: %C6KENV-SP-4-FANHPMODE: Fan-tray 1 is operating in high power mode
Aug 21 10:21:21 DST: %OIR-SP-6-REMCARD: Card removed from slot 4, interfaces disabled
Aug 21 10:21:38 DST: %OIR-SP-6-REMCARD: Card removed from slot 4, interfaces disabled
00:00:34: %SYS-DFC4-5-RESTART: System restarted --
Cisco IOS Software, c6lc2 Software (c6lc2-SP-M), Version 12.2(33)SXH2a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 25-Apr-08 09:52 by prod_rel_team
Aug 21 10:23:48 DST: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimal Diagnostics...
Aug 21 10:24:42 DST: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
Aug 21 10:24:43 DST: %OIR-SP-6-DOWNGRADE_EARL: Module 4 DFC installed is not identical to system PFC and will perform at current system operating mode.
Aug 21 10:24:44 DST: %SNMP-5-MODULETRAP: Module 4 [Up] Trap
Aug 21 10:24:44 DST: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
when i give show environment the following output getting for the fan tray
fan-tray 1:
fan-tray 1 type: WS-C6509-E-FAN
fan-tray 1 mode: High-power
fan-tray 1 fan-fail: OK
before installing the line card fan-tray 1 mode: was restricted power .
Can anybody tell me the difference between high power mode and restricted mode. Is this an informational message only?? Or do i need to do any thing further to sort this problem. Your early responese will be appreciated.
Edison Ortiz Thu, 08/21/2008 - 17:34
  • Hall of Fame,
    Founding Member
I suggest you open a TAC case, you may have a faulty hardware there.
__
Edison.
