CUCMBE CFA to AA
How do I mask the digits of a DN that is Call Forwarded ALL to another extension that then winds up in the Voicemail. The Unity is attempting to direct the call to a mailbox or Call handler based on the originating DN, while I would like it to use the forwarding DN treatment of the device that it is being forwarded TO. i.e.:
8992 (and others) are CFA to 7000 which then CFNA to an AA in the Unity. Unity is looking for something to associate 8992 with, while I would like it to play the AA that is associated with 7000. We have 10 sites (2801 SRST's) that are forwarding to the main site after hours so callers reach the AA.
I have a workaround where I have them forwarding to a DN that I CFA off switch and dials 481-7000(main number), but I'm thinking there must be an easier way.
Could someone clue me in?
Thanks in advance,
George
Rob Huffman Thu, 08/21/2008 - 04:44
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi George,
This is normal, if you are using most voicemail systems including Unity Connection or Pre-5.x Unity voicemail this is working as expected.
The problem (as you nicely noted :) lies in the fact that Unity Connection sees the First Redirecting or Originally Dialed number (8992's CLID rather than the Last Redirecting Number (7000's).
For this type of setup you can configure a Voicemail profile (in CCM) for 7000 and apply it to 8992 that will allow this type of Call Forward to 7000's AA mailbox. But this does remove the ability for 8992 to have a Personal Mailbox.
Hope this helps!
Rob
Marwan ALshawi Wed, 09/03/2008 - 19:36
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
have u tried to creat a CTI RP lets say it number is 5000
and on the phone number 7000 make the CFNA to 5000 and on the CTI make the CFA to voice mail
on on unity
creat call routing rule for forwarded or direct and match calling/called number then forwarded to 7000 voice mail
this can be done for each phone u want it to have this ability
in this case creat a CTI for each one as well
OR instead of making call routing rule
as we have created a cti creat VM profile for this CTI and make the VM profile mask as 7000 this case the call will be edned to 7000 VM
this should be done individualy for each number with its own CTI and VM profile
good luck
if helpful Rate
