Upgrading 4400
Aug 21st, 2008
I consider upgrading the software on our 4400 from 5.0.148 to 5.1.151, but when I look in the help on Downloading file to the controller, it says:
"The controller downloads and installs the new controller Operating System software. This process takes at least three minutes and overwrites your existing code and configuration."
Is this correct, that it overwrites the current configuration?
ahmedalshami Fri, 08/22/2008 - 00:31
yes
its correct but always take backup for your configuration before upgrading your Network equipments
thanks
Richard Atkin Fri, 08/22/2008 - 02:09
  • Silver, 250 points or more
The controller will change the config so it is suitable for the new code (allowing syntax changes, new commands, etc...) When you controller has rebooted, it will still do what it used to, it won't lose WLAN configs, IP addressing, etc...
When upgrading code, also remember that the APs will need to download their new code too, which takes about 3mins, and the controller can upgrade 10APs at a time. Therefore;
Total outage = Controller Outage + AP Outage
So if you have a hundred APs, the total time before the last AP returns to service is..
3.5 + (3 x [100/10]) = 33.5mins
HTH,
Richard
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
