Super G3 to Super G3 FAX from FXS to BRI
Answered Question
Aug 21st, 2008
Our customer is using CUCM 6.1 with ATA186 and 2811 H.323 (12.4(9)T) Gateways with ISDN BRI. Now they have installed a Super G3 FAX which can not be reconfigured to G3 speeds. Calls from that Super G3 FAX to other Super G3 FAXes don't work as the ATA186 does not support Super G3. Hence we inserted a VIC2-2FXS card in the gateway and configured it for SCCP with the CUCM and T.38 with "fax-relay sg3-to-g3". The FAX calls from the Super G3 FAX to other Super G3 FAXes still fail (calls are disconnected after approx. 8 sec). I think the fax relay configuration is not really used because when the call is established there is no VoIP call leg, just the 2 POTS call legs.
Has anyone successfully connected a Super G3 FAX to an FXS port an was able to fax with other Super G3 FAXes over a ISDN interface on the same gateway?
If so, please let me now.
Many thanks in advance
Stefan
Correct Answer by joe.bennett about 8 years 6 months ago
My understanding is that SG3 is not supported under fax-relay/T38 only under passthrough. As SG3 uses special tones standard fax pass-through doesn't recognise the setup so you need modem passthrough. I hope that this helps. There is a very good fax book produced by Cisco Press - do you have Safari?
Overall Rating: 4 (2 ratings)
pcameron Mon, 08/25/2008 - 03:55
  • Cisco Employee,
Following is a config for SCCP controlled faxing on the FXS port and MGCP controlled ISDN BRI. This had a SuperG3 fax on the FXS port 0/3/0 and worked fine at SG3 speeds after we added 'no fax-relay sg3-to-g3' under voice service voip settings. Putting this command back to the default would force the fax back to to normal T30 speeds.
Due to some other issues the customer later put the FXS port under MGCP control and this worked fine at SG3 speeds as well.
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-select 1 BRI0/1/0
stcapp register capability 0/3/2 modem-passthrough
stcapp register capability 0/3/1 modem-passthrough
stcapp register capability 0/3/0 modem-passthrough
stcapp register capability 0/3/3 modem-passthrough
stcapp ccm-group 1
stcapp
stcapp feature access-code
prefix *
stcapp feature speed-dial
prefix #
isdn switch-type basic-net3
voice-card 0
no dspfarm
dsp services dspfarm
voice service voip
modem passthrough nse codec g711ulaw redundancy maximum-sessions 5
interface BRI0/1/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn static-tei 0
voice-port 0/1/0
compand-type a-law
cptone AU
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone AU
bearer-cap Speech
voice-port 0/3/0
cptone AU
timeouts ringing infinity
timing hookflash-in 400 10
caller-id enable
voice-port 0/3/1
cptone AU
caller-id enable
voice-port 0/3/2
caller-id enable
voice-port 0/3/3
ccm-manager fallback-mgcp
ccm-manager redundant-host X.X.X.X
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
mgcp
mgcp call-agent X.X.X.X 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp cs3 signaling
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax rate 14400
no mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback2
mgcp bind media source-interface Loopback2
mgcp profile default
sccp local GigabitEthernet0/1.300
sccp ccm X.X.X.X identifier 1 version 4.1
sccp ccm X.X.X.X identifier 2 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
dial-peer voice 51 pots
service stcapp
port 0/3/0
dial-peer voice 52 pots
service stcapp
port 0/3/1
dial-peer voice 53 pots
service stcapp
port 0/3/2
dial-peer voice 54 pots
service stcapp
port 0/3/3
STEFAN CHRISTEN Mon, 09/15/2008 - 01:08
Hi Paul
Thanks for your reply.
Finally with the fax manual I was able to disable the Super G3 function (V.34) and then it worked fine.
I will try your configuration once I really need the Super G3 speed.
Stefan
Correct Answer
joe.bennett Mon, 09/29/2008 - 17:59
STEFAN CHRISTEN Tue, 09/30/2008 - 00:55
Hi Joe
Unfortunately we don't have Safari yet. Thanks for your post, the post from Paul already had a config for modem-passthrough.
Actually I was looking for "SG3 to G3 fall-back" which didn't really worked in my setup. Finally I was able to reconfigure the fax machine to G3.
Kind Regards
Stefan
