ASA. How to enable ICMP timestamp.
massimiliano.se... Thu, 08/21/2008 - 04:55
If the interface (say interface1)on which you want to reply a time stamp request message sent by a host (say host1) you must use this global configuration command:
icmp permit host host1 timestamp-reply interface1
I hope this helps.
Best regards.
Massimiliano.
massimiliano.se... Thu, 08/21/2008 - 05:36
Did you enabled logging...
What do you see?
Try with icmp permit ip_address_host1 subnet_mask_host1 timestamp-reply interface1
Massimiliano.
Farrukh Haroon Thu, 08/21/2008 - 08:26
Did you enable the command I sent you earlier?
In fact for testing just do this:
icmp permit any inside
Farrukh
Farrukh Haroon Thu, 08/21/2008 - 08:21
The 'Why not' was for the icmp command support on the ASA :)
Not for why the jitter is timing out.
Farrukh
