external calls disconnect
Answered Question
Aug 21st, 2008
CM 6.1
Phone 7937
I have installed a 7937 and internal calls in and out work fine
external incoming calls works fine
but external outgoing calls will ring but disconnect as soon as the user connects - have checked the config but cannot understand why this happens?
any ideas?
thanks in advance
Correct Answer by Jaime Valencia about 8 years 5 months ago
what codec are you using for the outgoing calls and are you using MGCP or H323?
sounds like a codec issue
java
if this helps, please rate
Overall Rating: 3 (1 ratings)
mlucas1911 Thu, 08/21/2008 - 05:04
You'll need to give me the config of the PSTN gateway. Is this FXO, PRI or T1?
Correct Answer
Jaime Valencia Thu, 08/21/2008 - 05:28
java
nickmac74 Thu, 08/21/2008 - 05:29
This was a routing issue and working fine now -thanks for the reply
