Red Status Light on the 4506
vtra
I tried searching the archives and google but couldn't find what this means anyone point me in the right direction? Thanks. Basically, the status light on the 4506 is red and no one connected to that switch has connectivity, i tried consoling in but it seems frozen even after reboot, does this mean the sup is gone?
satish_zanjurne
Level 4
Level 4
Yes !!!...Mostly SUP is gone, if you are not getting the console access also....
Try removing the SUP & resinserting again and see if it comes online.
HTH..
Look at Using LEDs to Identify Startup Problems
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/installation/guide/78-14409-08/05trblsh.html#wp1015099
If the problem persists Contacting the Cisco Technical Assistance Center
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/installation/guide/78-14409-08/05trblsh.html#wp1018250
I hope this helps.
Best regards.
Massimiliano.
Mark Yeates
Level 7
Level 7
Vinh,
It looks like you will need to RMA the supervisor in your switch. For your reference here is a guide to what the LED's mean.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/installation/guide/78-14409-08/05trblsh.html#wp1024760
HTH,
Mark
thanks a lot guys, it's the info i'm looking for!
Vin
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
