Cisco 2611 Terminal Server
Aug 21st, 2008
I have one of the 16 spider cables from my 2611 Terminal Server plugged into a console port of a device that exists behind the firewall. But, it does not appear to be working.
Config of 2611 Terminal Server below and output of show line when an attempt is made to connect the remote cisco router. I already have this solution working for other routers and all works.
Config of line 33 48 on terminal server:-
line 33 48
session-timeout 5
timeout login response 15
no exec
transport input telnet
transport output all
BunkerA_2nd_TS#sh host
Default domain is not set
Name/address lookup uses static mappings
Codes: UN - unknown, EX - expired, OK - OK, ?? - revalidate
temp - temporary, perm - permanent
NA - Not Applicable None - Not defined
Host Port Flags Age Type Address(es)
XIT 2041 (perm, OK) 0 IP 10.64.8.40
BunkerA_2nd_TS#
BunkerA_2nd_TS#sh line 41
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 41 TTY 9600/9600 - - - - - 15 0 0/0 -
Line 41, Location: "", Type: "SUN-CMD"
Length: 34 lines, Width: 80 columns
Baud rate (TX/RX) is 9600/9600, no parity, 2 stopbits, 8 databits
Status: Ready, Connected, Active
Capabilities: EXEC Suppressed
Modem state: Ready
Modem hardware state: noCTS DSR DTR RTS
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:10:00 00:05:00 none not set
Idle Session Disconnect Warning
never
Login-sequence User Response
00:00:15
Autoselect Initial Wait
not set
Modem type is unknown.
Session limit is not set.
Time since activation: 00:01:51
Editing is enabled.
History is enabled, history size is 20.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed input transports are telnet.
Allowed output transports are pad v120 telnet rlogin udptn.
Preferred transport is telnet.
No output characters are padded
No special data dispatching characters
Richard Burts Thu, 08/21/2008 - 10:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mary
I wonder about this line of output:
and wonder what happens if you issue the command clear line 41 from privilege mode of the terminal server?
The output shows that it has been used 15 times. Has it worked before or has it ALWAYS failed?
If you remove the terminal server cable and connect directly to the router console port with a PC does it work?
If you connect a different cable from the terminal server to the router and attempt access with the different reverse telnet port does it work?
If you can provide answers to these we might be closer to having answers to your issue.
Rick
