Event Type Groups / Rule behavior
Answered Question
Hello All,
I am having trouble understanding the different Event Type Groups used in the different Mars Rules. For example When Looking throught incidents generated I found
port Scans
ping sweeps
server scans for specific ports
and others
that are all being fired under the rule
System Rule: Network Activity: P2P File Sharing - Active
or under the rule
System Rule: Network Activity: Excessive Denies - Host Compromise Likely.
When looking closer at these rules I have noticed the contain some (what I thought were) very generic event type groups.
Is there a resource that you guys know of that describes or goes into details about the event type groups? I have tried most of the Cisco recommended mars books, and havent found much detail.
-Thanks.
Correct Answer by Farrukh Haroon about 8 years 8 months ago
There is only limited description about these at the end of the MARS user guide.
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/5.3/user/guide/local_controller/appmars.html
These are the most annoying 'RULES' in MARS and you usually have to tune them using either at the reporting device or on MARS itself. The device-side tuning is more preferred but is not always possible.
Farrukh
Overall Rating: 3 (1 ratings)
Correct Answer
Farrukh Haroon Thu, 08/21/2008 - 12:39
  • Red, 2250 points or more
Farrukh
