FWSM Failover takes more than 15 seconds !
Aug 21st, 2008
I know this question has been posted last year already, however without a clear answer.
I have two FWSM (version 3.2(2) installed on two different switches. The FWSM are configured with two contexts ,running in active/standby mode.
I use two different VLANs for the failover and synchronization. manual switchover (with the no failover active command) works fine, TCP sessions are taken over, no problem.
However, if the primary unit fails (power off), the secondary unit take up to 15 seconds to take over. I tuned the unit poll frequency to 500 msec with a holdtime of 3 seconds.
What can be wrong ?
Here is the config on the primary unit :
SYSTEM# sh run failover
failover
failover lan unit primary
failover preempt 60
failover lan interface FAILOV Vlan10
failover polltime unit msec 500 holdtime 3
failover replication http
failover link STSYNC Vlan11
failover interface ip FAILOV 192.168.10.1 255.255.255.0 standby 192.168.10.2
And the replicated version on the secondary unit :
failover
failover preempt 60
failover interface ip STSYNC 192.168.11.1 255.255.255.0 standby 192.168.11.2
Thank you for any help
Yves Haemmerli
yves.haemmerli Thu, 08/21/2008 - 06:53
Andrew,
This command dos not exist on my FWSM... maybe an ASA command ?
Yves
Yes - sorry, checking the wrong device config!
Below is my fwsm failover config, it fails over in 3 seconds:-
failover
failover preempt 300
failover lan interface failover Vlanxxx
failover polltime unit 1 holdtime 3
failover polltime interface 3
failover interface-policy 1
failover link failover Vlanxxx
failover interface ip failover x.x.x.x 255.255.255.252 standby 1x.x.x.x
yves.haemmerli Thu, 08/21/2008 - 07:38
Andrew,
I added the interface-policy 1 statement and the failover polltime interface 3 statement to my config, but the result is the same...
So my config is now :
failover
failover preempt 60
The only difference I have is that you maybe use the same VLAN for both failover and sync ? but anyway, it shouldn't have any impact
Yves
yves.haemmerli Thu, 08/21/2008 - 07:59
Andrew,
I did the change, but unfortunately there is no change on the behaviour...It is really strange.
Do you have the stement "firewall autostate" statement on your 6500 switch config ?
Yves
yves.haemmerli Thu, 08/21/2008 - 08:12
Andrew,
Here is the command show failover output on the primary and secondary units :
On the primary :
SYSTEM# sh failover
Failover On
Failover unit Primary
Failover LAN Interface: FAILOV Vlan 10 (up)
Unit Poll frequency 1 seconds, holdtime 3 seconds
Interface Poll frequency 3 seconds
Interface Policy 1
Monitored Interfaces 0 of 250 maximum
Config sync: active
Version: Ours 3.2(2), Mate 3.2(2)
Last Failover at: 15:53:01 UTC Aug 21 2008
This host: Primary - Active
Active time: 545 (sec)
ADMIN Interface FWMGT (10.56.2.12): Normal (Not-Monitored)
CH01FW01 Interface V-300-P (10.56.5.1): Normal (Not-Monitored)
CH01FW01 Interface V-400-P (10.56.9.1): Normal (Not-Monitored)
Other host: Secondary - Standby Ready
Active time: 596 (sec)
ADMIN Interface FWMGT (10.56.2.13): Normal (Not-Monitored)
CH01FW01 Interface V-300-P (10.56.5.2): Normal (Not-Monitored)
CH01FW01 Interface V-400-P (10.56.9.2): Normal (Not-Monitored)
Stateful Failover Logical Update Statistics
Link : STSYNC Vlan 11 (up)
Stateful Obj xmit xerr rcv rerr
General 228 0 87 0
sys cmd 88 0 88 0
up time 0 0 0 0
RPC services 0 0 0 0
TCP conn 0 0 0 0
UDP conn 0 0 0 0
ARP tbl 141 0 0 0
Xlate_Timeout 0 0 0 0
AAA tbl 0 0 0 0
DACL 0 0 0 0
Logical Update Queue Information
Cur Max Total
Recv Q: 0 1 612
Xmit Q: 0 0 229
An here on the secondary :
SYSTEM# sh failover
Failover On
Failover unit Secondary
Interface Policy 1
Config sync: active
Last Failover at: 15:53:39 UTC Aug 21 2008
This host: Secondary - Standby Ready
Other host: Primary - Active
Active time: 663 (sec)
General 2520 0 7981 0
sys cmd 2124 0 2117 0
up time 0 0 0 0
TCP conn 24 0 20 0
UDP conn 0 0 4 0
ARP tbl 373 0 5841 0
AAA tbl 0 0 0 0
DACL 0 0 0 0
Cur Max Total
Recv Q: 0 2 25275
yves.haemmerli Fri, 08/22/2008 - 01:21
Hi Andrew,
I really appreciate your help, as I am a bit stuck with this issue in an important data center...
In the troubleshooting document, I read : "Note: Do not configure an IP address for the failover link or for the state link (if you are going to use Stateful
Failover)."
But in the sample configuration, they configure an IP address ??? I also configured an IP address on the failover VLAN and on the Sync VLAN (remember, I use two diferent VLANs, as recommended by Cisco).
For your information, here is my SYSTEM configuration :
SYSTEM# sh run
: Saved
FWSM Version 3.2(2)
resource acl-partition 12
hostname SYSTEM
enable password xxx
interface Vlan10
description LAN Failover Interface
interface Vlan11
description STATE Failover Interface
interface Vlan91
description *** Network Management VLAN ***
interface Vlan300
description *** Server Farms VLAN ***
interface Vlan400
description *** Critical Servers VLAN ***
passwd /qNhaw.ZtG3q1e1B encrypted
class default
limit-resource IPSec 5
limit-resource Mac-addresses 65535
limit-resource ASDM 5
limit-resource SSH 5
limit-resource Telnet 5
limit-resource All 0
ftp mode passive
pager lines 24
failover
failover preempt 60
no asdm history enable
arp timeout 14400
console timeout 0
admin-context ADMIN
context ADMIN
description *** This is the administration context. It has a unique interface on VLAN 91 ***
allocate-interface Vlan91
config-url disk:/ADMIN.cfg
context CH01FW01
description *** This is the Firewall instance between security zones 3 and 4 ***
allocate-interface Vlan300
allocate-interface Vlan400
config-url disk:/CH01FW01.cfg
prompt hostname context
Cryptochecksum:xxx
: end
In your environment, do you monitor any interface in addition to unit monitoring ? If yes, what interface do you monitor ? I have basically two contexts in my FWSM : the ADMIN context, with a unique interface on my management vlan and another context for production, with two interfaces (inside and outside).
Yves
yes - I monitor the failover interface:-
failover lan interface failover Vlan256
failover link failover Vlan256
failover interface ip failover 10.x.x.245 255.255.255.252 standby 10.x.x.246
yves.haemmerli Fri, 08/22/2008 - 02:13
Andrew,
Do you understand what Cisco means when writing :
Failover)." ?
Actually, we both have configured IP addresses on the failover VLAN :
Yves
Yes - it's becuase you do not want the state link IP being transfered in the event of failover?
As below that note - there is this one:-
Note: You do not need to identify the standby address subnet mask. The failover link IP address and MAC address do not change at failover. The active IP address for the failover link always stays with the primary unit, while the standby IP address stays with the secondary unit.
yves.haemmerli Fri, 08/22/2008 - 04:49
Andrew,
i think I come narrow to the problem. With proper debug messages enabled, I can see that the FW02 (the standby) makes several ARP checks on the other firewall interfaces, before declaring FW021 dead...
Here are the messages with comments :
SYSTEM# debug fover ifc
SYSTEM# debug fover cable
SYSTEM# debug fover fmsg
SYSTEM# debug fover sync
SYSTEM debug timestamp 255
1636.170000000: fover_health_monitoring_thread: fover_lan_check() Failover Interface OK
1638.170000000: fover_health_monitoring_thread: fover_lan_check() Failover LAN Check
1638.170000000: fover_health_monitoring_thread: fover_lan_check() Failover Interface OK
FW01 Fails now !
1638.170000000: fover_health_monitoring_thread: fover_luifc_check: ifc rcv fail cnt = 1
1639.170000000: fover_health_monitoring_thread: fover_lan_check() Failover LAN Check
1639.170000000: fover_health_monitoring_thread: fover_lan_check() Failover Interface TEST started
1639.170000000: fover_health_monitoring_thread: send_mate_arp(1) - 192.168.10.1
1639.170000000: fover_health_monitoring_thread: send_mate_arps(50001) - 10.56.2.12
1639.170000000: fover_health_monitoring_thread: send_mate_arps(60001) - 10.56.5.1
1639.170000000: fover_health_monitoring_thread: send_mate_arps(60002) - 10.56.9.1
1639.170000000: fover_health_monitoring_thread: fover_luifc_check: ifc rcv fail cnt = 2
1640.170000000: fover_health_monitoring_thread: fover_lan_check() Failover LAN Check
1640.170000000: fover_health_monitoring_thread: send_mate_arp(1) - 192.168.10.1
1640.170000000: fover_health_monitoring_thread: send_mate_arps(50001) - 10.56.2.12
1640.170000000: fover_health_monitoring_thread: send_mate_arps(60001) - 10.56.5.1
1640.170000000: fover_health_monitoring_thread: send_mate_arps(60002) - 10.56.9.1
1640.170000000: fover_health_monitoring_thread: fover_luifc_check: ifc rcv fail cnt = 3
... 15 seconds
1655.170000000: fover_tx: putit(cmd = b) seqNum 0x8fd, no response, retry=10, busyack=0
1670.170000000: fover_tx: putit(cmd = 9) seqNum 0x8fe, no response, retry=10, busyack=0
1670.170000000: fover_tx: comm_alarm(0, reason 3)
1670.170000000: fover_FSM_thread: Vlan status(DOWN) update Time: 0
1670.170000000: fover_FSM_thread: MAC update Time: 0
1670.180000000: fover_FSM_thread: IP update Time: 0
1670.190000000: fover_FSM_thread: Vlan status(UP) update Time: 0
1671.170000000: fover_health_monitoring_thread: fover_lan_check() Failover LAN Check
1671.170000000: fover_health_monitoring_thread: send_mate_arp(1) - 192.168.10.1
1671.170000000: fover_health_monitoring_thread: send_mate_arps(50001) - 10.56.2.13
1671.170000000: fover_health_monitoring_thread: send_mate_arps(60001) - 10.56.5.2
1671.170000000: fover_health_monitoring_thread: send_mate_arps(60002) - 10.56.9.2
1671.170000000: fover_health_monitoring_thread: fover_lan_check() Failover LAN Check - Timeout
1671.170000000: fover_health_monitoring_thread: fover_luifc_check: skip lu ifc monitoring
Farrukh Haroon Mon, 08/25/2008 - 18:33
  • Red, 2250 points or more
You have to monitor the interfaces to make your failover work properly. Use the 'monitor-interface' command for this purpose. The failover link 'does not' need to be put in the monitor-interface command.
Secondly what that Cisco quote means, IF you are 'sharing' the failover and stateful links you don't need to configure the IP address of the stateful link. However if you don't share them, then the need for the IP address on the STATEFUL link also exists.
Using 'default configuration's the FWSM failovers in about 2-3 seconds.
Farrukh
yves.haemmerli Tue, 09/02/2008 - 03:34
Hi all,
Just to let you know that my FWSM failover problem has been solved after upgrading the code from 3.2(2) to 3.2(6) !
Now, the switchover is executed in 3 second, as expected.
Thank you all for your help and contribution
Yves Haemmerli
Farrukh Haroon Tue, 09/02/2008 - 07:53
Thank you for the update, it will really help all those that lookup this problem in the future.
Farrukh
