IPMProcess shutdown by administrator
Answered Question
Aug 21st, 2008
just upgraded LMS 3.0 to 3.1
server is running solaris 5.10
LMS is integrated with ACS 4.1
cannot run IPM as process is down.
if I start the process manually it
is shutdown after a few seconds.
all other processes including an evaluation copy of HUM are working
normally.
any ideas?
Correct Answer by Joe Clarke about 8 years 7 months ago
Looks like a problem with your IPM database caused by the migration (or perhaps a patch you had applied to IPM 4.0.1). If you don't have any data in this database you need preserved, you can simply reinitialize it:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=ipm dmprefix=Ipm
If you do have data to preserve, you'll need to contact the TAC to correct this problem as it will involve some direct database access.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 08/21/2008 - 07:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the output of the /opt/CSCOpx/bin/pdshow command.
Joe Clarke Thu, 08/21/2008 - 09:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the ipmprocess.log and the daemons.log.
Correct Answer
Joe Clarke Fri, 08/22/2008 - 07:58
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
