08-21-2008 08:10 AM - edited 03-09-2019 09:19 PM
Hello all,
I have ASA 8.0(2) and never run ASDM before. I just download ASDM launcher v1.3(30) but I was never able to connect to my ASA via ASDM. Can someone help?
thanks,
Gene
08-21-2008 08:21 AM
What is the error you get while trying to connect with ASDM ?
Some possible problems -
- Your system IP is not allowed for HTTP management in the ASA config.
- incorrect version of JAVA on your system.
08-21-2008 09:24 AM
The error message is:
ASDM is unable to continue loading. Click OK to exit from ASDM. Unconnected sockets not implemented.
This happens when I try to connect to both ASA5520 and ASA5510.
thanks,
Gene
08-21-2008 09:35 AM
" Unconnected sockets not implemented. " This seems to be a JAVA problem.
Try reinstalling JAVA preferable an updated version.
09-28-2008 03:18 PM
You need to download Jave 2 SE v1.4.2.... If you have the latest version of Java it won't work.
http://java.sun.com/j2se/1.4.2/download.html
Click on "Download J2SE JRE"
This should fix your problem.
Patrick
10-08-2008 06:48 AM
This not resolve the problem.
