condition overflow
anitachoi3
I configure the XM with IPIP function and it works fine. However, I find that some calls will go to dial-peer 4403. It seems that some calls fail to terminate to dial-peer 4401 and 4402, it flows to dial-peer 4403.
I would like to enable the "condition overflow" function below
- All calls must go to dial-peer 4401 and 4402 for normal situration. The call will not flow to dial-peer 4403 if the gateway 192.168.16.20 OR 192.168.17.120 are up.
- When the gateway 192.168.16.20 AND 192.168.17.120 are down, the calls should flow to dial-peer 4403 only.
How do I change the configuration?
rdgs
R1
dial-peer voice 4401 voip
no prefer
destination-pattern 44.
session target ipv4:192.168.16.120
dial-peer voice 4402 voip
prefer 1
session target ipv4:192.168.17.120
dial-peer voice 4403 voip
Description: Internet
prefer 2
session target ipv4:202.x.x.x
Marwan ALshawi
try the following
prefer 1
hunt-stop
prefer 3
I try it but the call cannot overflow to "4403" dial peer. There is one call leg only, router cannot find the right dial-peer (voip) when 192.168.x.x gateway are down.
If I enable the gateway, the call can over flow from 4401 to 4402.
Anything I missing?
rdgs
Marwan ALshawi
try ur origianl config with this voice-calss and simple chabge as the following:
voice class h323 1
h225 timeout tcp establish 3
preference 0
voice-class h323 1
prefer 1
voice-class h323 1
prefer 2
and make sure u have the right routing config
i mean u ca ping the internet host and u have two routes! some times it be routing issue!!
good luck
and let me
Some calls still flow to dial-peer 4403 if 4401 and 4402 fail to terminate the calls.
Any work around or solution for "condition overflow"? Thanks
rdgs
