ACS with Multiple Domains
Aug 21st, 2008
I have a ACS server (3.3) and would like to authenticate to multiple AD domains that are not trusted together. I do have ACS 4.2 if needed. From what I understand it looks possible to do if you add the other AD domains as generic LDAP. If that is the case is there any resource that will explain how to set this up?
hadbou Wed, 08/27/2008 - 05:49
The most reliable method of authenticating users against a specific domain is to require users to submit the domains that they should be authenticated against along with their usernames. Authentication of a domain-qualified username is directed to a specific domain; rather than depending on Windows to attempt authentication with the correct domain or on using the Domain List to direct ACS to submit the username repeatedly in a domain-qualified format.
krishanmistry Wed, 08/27/2008 - 12:03
Hi Hadbou
How would you get the users to submit the domain that they should be authenticated against along with there username.
I am using windows zero config, to manage my wireless connection.
