Is there a way to change MTU size on LWAPP
Aug 21st, 2008
My customer is running a guest access vlan and is being directed to a firewall. He says the FW is set to not handle packet size over 1500.
Is there a way to adjust the packet size on the LWAPP side to limit it to 1500?
Scott Fella Fri, 08/22/2008 - 05:45
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
What I have been told and heard, is that this can't be changed. If you search the forum on lwapp mtu, there are others out there with issues similar to yours.
kdavison007 Fri, 08/22/2008 - 10:48
We ran into this issue with sites that were on a site to site VPN. disabling the df bit fixed that, but what you can do to get around the MTU issue is run the access point in HREAP mode if it supports that feature. Then data isn't sent through the LWAPP tunnel. The other option is to change the MTU on your clients to 1400 something. It's not ideal to do that unless you only have a few clients.
Trending Topics - Security & Network
