Remote Access- ASA
Aug 21st, 2008
Moving from VPN Concentrator to ASA for Remote Access.
I tested the following configuration but no luck, user accounts are created on ACS and cannot get authenticated.... I am missing something still....
==========Remote-Access-Config=======
ip local pool JK 192.168.10.1-192.168.10.150 mask 255.255.255.0
group-policy PAK-TEL internal
group-policy PAK-TEL attributes
wins-server value 192.168.1.100
dns-server value 192.168.1.100
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group PAK-TEL type ipsec-ra
tunnel-group PAK-TEL general-attributes
address-pool JK
default-group-policy PAK-TEL
tunnel-group PAK-TEL ipsec-attributes
pre-shared-key *
telnet timeout 1440
Overall Rating: 4 (1 ratings)
acomiskey Thu, 08/21/2008 - 13:06
  • Green, 3000 points or more
Do you have something like?
access-list inside_nat0_outbound extended permit ip 192.168.10.0 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
Amin Shaikh Thu, 08/21/2008 - 14:20
Yes, I have this...
when I have local-user on ASA ; it works.
But how could the traffic forward to ACS Server...
Premdeep Banga Thu, 08/21/2008 - 14:36
  • Gold, 750 points or more
Are you sure, you have something like this on configuration,
aaa-server RADIUS-SERVER protocol radius
aaa-server RADIUS-SERVER () host
authentication-server-group RADIUS-SERVER
Assuming that you are using Radius protocol for authentication and ACS is configured accordingly.
Try to use following test command to ensure that authentication is working against the ACS server,
test aaa-server authentication host
e.g.,
test aaa-server authentication RADIUS host 1.2.3.4
Prem
Amin Shaikh Fri, 08/22/2008 - 01:02
Thanks.
I dont see any failed/passed info under Reports-logging on ACS..
On ACS the following is done
ASA added under AAA client with shared key
Radius authentication
rename group5 on ACS as PAK-TEL
No Luck so far...
Premdeep Banga Fri, 08/22/2008 - 04:56
Renaming Group to PAK-TEL is not required, its only for your management comfort only.
One question, are you able to authentication using the current ACS against any other device ? Or is ASA is the only one that you are trying to authenticate. Could be that ACS is not configured properly, by that I mean "Proxy Distribution Table" is not configured properly.
If this is the first time you are trying to authenticate on ACS, then please enable Passed Reports as it is disabled by default.
The very first thing that should be successful, in order to get VPN users authenticated is, to ensure that the "test aaa...." command is successful from the ASA, if that does not succeed, then no point in testing using VPN client.
Make sure that nothing is blocking the Radius traffic in between i.e b/w ASA and ACS.
What is the result of the test command, is it,
"ERROR: Authentication Server not responding: No error" ?
Or something else ?
Prem
Please rate if it helps!
