IPCC Express - Premium Blank Recordings
Aug 21st, 2008
I have a customer where we installed Premium and recording was working. At some point over the past week, it has somehow stopped. The scenario is that the system creates a .raw entry once the recording has began, but when attempting to check the recording via the server or via supervisor desktop, there is no sound. The file also just shows up as a 1Kb raw file.
Any help would be appreciated as this is a feature the customer truely needs.
arcaidy76 Tue, 08/26/2008 - 21:32
  • Bronze, 100 points or more
How are you recording? Via the phone or span? I had this problem when using the phone and desktop client and it was the windows firewall. Disable it and see if it helps.
Jonathan Schulenberg Wed, 08/27/2008 - 02:38
  • Cisco Designated VIP,
    2017 IP Telephony
I've also seen this issue with commercial anti-malware software that has an integrated firewall in it. In one case, even when the firewall was "off", it was still blocking the traffic. Similar to what you experienced it just stops working, likely to a definition update by the vendor that starts dropping the packets.
