Filter for Subject beginning with...
Aug 21st, 2008
Can someone help with a GUI subject filter I have defined? I've got a dictionary of subjects I'm quarantining and this one has me stumped. I need to filter subjects that begin with - [RochesterMI-Freecycle] - including the backets (not the hyphens). Any help would be appreciated. Thanks.
kluu_ironport Thu, 08/21/2008 - 15:59
You need to add the backward slash (\) in front of special characters so that the scanning system will know to treat it as a regular bracket ([). Same goes for the close bracket.
^(?i)\[Rochestermi-freecycle\]
^ --> begin of line
\ ---> deference the next character to make it mean the literal character
(?i) ---> ignore case
Taken from the AsyncOS Advanced User Guide
The backslash character escapes special characters. Thus the
sequence \. only matches a literal period, the sequence \$ only
matches a literal dollar sign, and the sequence \^ only matches a
literal caret symbol. For example, the regular expression
^ik\.ac\.uk$ only matches the string ik.ac.uk.
Important Note: The backslash is also a special escape character for
the parser. As a result, if you want to include backslash in your regular
expression, you must use two backslashes — so that after parsing,
only one “real” backslash remains, which is then passed to the regular
expression system. So, if you wanted to match the example domain
above, you would enter ^ik\\.ac\\.uk$.
