Aironet 1252 with catalyst 2960-8TC-L & router 1841 compatibilty
Answered Question
Aug 21st, 2008
First are they togther a good combination?
I'm going to buy new ap 1252 and catalyst switch 2960-8TC-L my question can I connect the ap to port 1x10/100/1000Base-T/SFP (mini-GBIC)(uplink)?
because to work on ap with full capacity 300 mbps it needs 1000 port, for powering ap I'll use powerinjector .
this will sereve 15 pc as a workgroup and 60 clients on wlan.
saher
Correct Answer by Scott Fella about 8 years 5 months ago
Depending on what kind of traffic and bandwidth requirements the clients require, you might need a couple more ap's which means you might have to settle for a 24 port switch. Cisco recommends 15 - 25 users per so, but again, you can have more if it's just email and web browsing.
Overall Rating: 4 (1 ratings)
Correct Answer
Scott Fella Fri, 08/22/2008 - 04:50
s.abubasheer Fri, 08/22/2008 - 13:30
thanks fella5, yes it's just for email and web browsing only,please still need a clear answer for my question can I connect the ap to that port 1x10/100/1000Base-T/SFP (mini-GBIC)(uplink), as a vlans trunk port ?
regards
saher
Trending Topics - Security & Network
