Jaime Valencia Thu, 08/21/2008 - 14:26
that would require you to write down your own directory script or to modify the one that's provided to accomplish that
other option would be to use AD and have them both look at the same user search base, meaning integrate both to the same AD
java
if this helps, please rate
