Cisco ASA 8.0.4 AnyConnect not working with Vista and IE7
Answered Question
Aug 21st, 2008
I currently have a Cisco ASA 5520 with all the latest version of Software ASA/ASDM/Anyconnect. however I cannot get Vista and IE7 to Connect using the anyconnect clientless VPN the following error is displayed
"The installer was not able to start the Cisco VPN Client."
Is there a workaround for this.
Thanks in advance
eoin
Correct Answer by Farrukh Haroon about 8 years 5 months ago
I'm glad you have it working :)
Please rate the posts if you find them helpful.
Farrukh
Overall Rating: 5 (2 ratings)
Farrukh Haroon Sat, 08/23/2008 - 03:28
Are you sure you are using Anyconnect or the (old) SVC client? This is usaully due to Java/ActiveX settings in your browser. Try adding the SSL host as a trusted host.
Farrukh
Farrukh Haroon Sat, 08/23/2008 - 03:33
Also make sure you have defined the SVC image in the ASA configuration (and its still there):
svc image disk0:/anyconnect-....
Farrukh
eoin@belfort.ie_2 Mon, 09/08/2008 - 10:04
Thanks Farrukh
that solved the problem the SVC image statement was pointing to an old version of anyconnect.
It's working ok now.
eoin
Correct Answer
Farrukh Haroon Mon, 09/08/2008 - 10:36
Farrukh
