Setting up a Callcenter
Aug 21st, 2008
I've setup some test phones to work on configuring a Call Center and its working great. My next question is how does it know which phones are active? If onlyone individual is answering the phone how does it know not to route to the an unmanned phone?
rob.huffman Thu, 08/21/2008 - 14:43
Hi John,
In a standard Call Centre setup the calls will only be routed to an Agent that is Logged In and available to take calls. All calls that cannot be routed to an Agent immediately will be Queued up to listen to MOH or Messaging. Once an Agent becomes available the next caller in line will be routed accordingly :)
Hope this helps!
johnbonog Thu, 08/21/2008 - 14:52
That's my question is how do I configure the phones so the system knows someone is using it. We are not using the Call Center software on the computer. Thanks!
johnbonog Fri, 08/22/2008 - 08:15
I'm not sure what the contact center software is? I'm not sure if we have it!
a.gooding Fri, 08/22/2008 - 17:03
k but you said you had setup some new phones for the contact centre right? what exactly did you do so far?
if possible a little background on its operation would be great
