Cisco ASA5500 WebVPN - Webfolders/WebDav not working Vista and IE 7
I currently have and ASA 5500 configured for webvpn for network Access using the portal webpage and CIFS configured bookmarks to point to network shares on the LAN. I can successfully connect, open and Save documents directly back into the cifs share using the Webfolders option (web folder icon) using IE7 and XP. however the webfolders option when using IE7 and Vista is not available. when I open a doc in from the portal in vista it will open in a local temp directory and I cannot save it directly back into the portal and CIFS file share.
Is this a know problem and is there a work around.
