Routing question
Aug 21st, 2008
I have a facility in Mexico that has limited WAN bandwidth. In order to speed up connectivity to a server located in another facility, I setup a VPN connection between the two sights, and created static routes on a layer 3 switch so the traffic from Mexico to the server goes across the VPN connection. How do I move the traffic from that server to the network in Mexico? All other traffic from that sight to Mexico needs to go across the WAN connection.
Edison Ortiz Thu, 08/21/2008 - 17:25
  • Hall of Fame,
    Founding Member
You can configure Policy Based Routing on the current gateway router.
You need to match the source (the server) and destination (Mexico network) - if there is a match, set the next hop to the VPN connection.
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_ip_prot_indep_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1056703
HTH,
__
Edison.
