Finding Duplex Mismatch in SYSLOG
Aug 21st, 2008
Is there a way to find "Duplex Mismatch" errors on devices in Ciscoworks? I need to find all devices in my CW that are getting these errors. I can see these in the sh logg of devices, but need to create a report showing all devices doing this.
Here is a snipet of a log:
Aug 12 01:00:31 local7:info Aug 12 00: 52:20 101416: Aug 12 00:52:19: %CDP-4-DUPLEX_MISMA
TCH: duplex mismatch discovered on FastEthernet0/11 (not half duplex), with FastEthernet0.1 (half duple x).
Joe Clarke Thu, 08/21/2008 - 19:03
If you are sending syslog messages to the CiscoWorks server, you can go to RME > Reports > Custom Report Templates, and create a new Syslog custom report that filters on:
Facility: CDP
Sub-facility: *
Severity: 4
Description: *
Once the report is created, you can run it from RME > Reports > Report Generator > Syslog.
