Using dot11 as a WAN interface
Aug 21st, 2008
I'm trying to connect a remote office to a central network using the routers dot11 interface to serve as the WAN connection between the two networks. Unfortunately, I've had a hard time finding relevant documentation. Any suggests or direction to documentation would be much appreciated.
Note: The router in question in the 871W.
Matt McCann
mccann.matt Sun, 08/24/2008 - 18:54
I am a student at Ohio State University and the university provides campus-wide WiFi that the students pay a hefty "Technology Fee" to help provide. Now that I am moving off campus, I was hoping to bridge the rather large gap between my new home and the nearest point of broadcast so that I can avoid having to purchase internet access. Hence the need to route traffic over the dot11
Well you would need to know if:-
1) They have a specific infrastructure SSID
2) You have access to the pre-shared key
3) You have the correct equipment - i.e wireless AP
4) You could then setup your equipment as a non-root ap, configure the wireless user SSID, and voila - free wireless.
HTH.
mccann.matt Thu, 08/28/2008 - 16:23
Yes, I have all of those things covered. So basically, all I really need to know at this point is how to configure the router to bridge the wireless. Now if I could just find a tutorial on the matter...
Giuseppe Larosa Fri, 08/22/2008 - 01:07
  • Hall of Fame,
    Founding Member
Hello Matt,
use the following link:
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html#wpxref79536
configure both wireless lans on the same ip subnet in the remote router you need a defaul route pointing to central site.
On central site a static route for the remote site's lan.
And of course NAT if internet access is desired
Hope to help
Giuseppe
