VPN client failover scenario
Aug 21st, 2008
Is this possible to have failover facility?
I mean to say: i have DC & DR where edicated Internet links are available. If at any point of time DC fails, VPN client automatically will shift to DR.
Overall Rating: 4 (1 ratings)
Marwan ALshawi Thu, 08/21/2008 - 21:08
its depend on ur topology?
if u are giving a vertual IP address to ur client that represent those both VPN it works or using failover with ASA but if u use defrent IPs for each vpn termination point inthis case the failover needs reestblitioment to the vpn and u need to add the second IP for the second vpn device as a backup IP in the vpn client software
good luck
please if helpful rate
