Call Manager 6.1 licences
Aug 21st, 2008
Hi Guys, I have 2 Call Managers 6.1 connected using interclustering, but finally in different cluster with its own resources and licences, if I wanted to share ip phone licences between them, is it possible ? or If I wanted to remove some licences from one CM and use them in the other one, is that possible?
Chris Deren Thu, 08/21/2008 - 21:22
It is not possible to share license between clusters, you can not remove a license from one appliance based CM to another, you would have to work with Cisco licensing team on that.
j.muozmellado Fri, 09/05/2008 - 08:19
Hello Chris....
Sorry for the delay and thanks for your answear. It helps me a lot. Best regards
Chris Deren Fri, 09/05/2008 - 08:47
NP, glad to help you out, please rate the post if it was helpful.
