Aug 21st, 2008
What would happen if a edge port (set with portfast) recieved a BPDU from another switch. We are running Rapid-PVST? would this cause a loop?
Overall Rating: 3 (2 ratings)
Marwan ALshawi Thu, 08/21/2008 - 21:05
never ever make a linke between two switches as portfast because portfast take the port from the blocking to forwarding state directly so this port will not be in blocking or even wont participate in root elction prosess it is only used with access port to avoid problems that happen especially when the client in the access port takeing its IP from a DHCP server
please, if helpful Rate
