show snasw pdlog detail explain
Answered Question
Aug 21st, 2008
i use command:show snasw pdlog detail,
and the result as followed:
ISR Session Deactivated
FQPCID = BOCOMNET.P101EN :DEF318026C1BD4B5
Deactivation reason = 0x0F
Pri->Sec: All frames = 0x0001557E
Pri->Sec: FMD frames = 0x0001557D
Pri->Sec: Bytes = 0x02661D7E
Sec->Pri: All frames = 0x0001557E
Sec->Pri: FMD frames = 0x0001557D
Sec->Pri: Bytes = 0x02661D7E
From ../dcl/ncmquery.c 1019 :at 9:58:12, 22 August 08
please note:Deactivation reason = 0x0F
how can i know what is meaning of 0x0F?
who can tell me where i can found the explain about the code:0x0F?
thanks!
Correct Answer by rclousto about 8 years 11 months ago
There is a brief message explanation and recommendation for each console message that corresponds to each pdlog entry at
http://www.cisco.com/en/US/docs/ios/12_4/system/messages/Vol2/sm_27h.html .
There is nothing to describe all of the details of the detailed pdlog. We try to make the pdlog as useful as reasonable for you, the customer, to use, but we also have many details for support to use in conjunction with reading the code, that would probably be too complex to try to explain.
This is the Unbind Type field in byte 1 of the Unbind. SNA Formats has the description of that field.
0x0F is
cleanup: the node sending UNBIND is resetting its half-session before receiving the response from the partner node
Overall Rating: 5 (2 ratings)
Correct Answer
rclousto Fri, 08/22/2008 - 05:11
0x0F is
xh_liu Fri, 08/22/2008 - 05:34
thanks first.
can you tell me any more reference guide or link about how to read 'show snasw pdlog detail' output?
Correct Answer
rclousto Sun, 08/24/2008 - 16:17
