Marwan ALshawi Thu, 08/21/2008 - 23:19
just go to bat manue and chose updat then make a choice to ubdat phone users whaever then make a selction based on a query
like all phones in partiion P1 and so on
good luck
paulhardy Fri, 08/22/2008 - 15:04
Thanks for the update. But I need to know how to complete the specific field in CallManager 6 on the line and the user associated with it. I am hoping for a way to get this done by csv file
Michael Owuor Fri, 08/22/2008 - 16:28
Paul,
Try these steps:
1. Create a csv file. Here's a sample that I used:
User ID,Device,Directory Number,Partition
user1,SEP00AABBCCDDEE,2001,
Leaving the partition blank means the default partition for the extension is used.
2. Upload the csv file under Bulk Administration, Upload/Download Files. Set the target to User Line Appearance, and Set the Select Transaction Type to 'Update Line Appearance - Custom File'.
3. Go to Bulk Administration, Users, Line Appearance, Update Line Appearance.
4. Select the previously uploaded csv file and immediately run the job.
Try it with for a couple of lines first and see if that works for you.
Hope this helps.
Michael.
tbergquist Tue, 10/07/2008 - 18:16
Hi Paul,
Did you find that this solution worked? It did not for me and was wondering if your last posting on this meant you found another solution?
vinhnguyen Tue, 06/29/2010 - 22:48
Hi Michael
What do you put if it is a device profile not a physical phone?  I am keep on getting error like
user id Error Code Error Description
ADOUGLAS On row 1: bad device name
Result Summary :
Update for 0 Line Appearance passed.
Update for 1 Line Appearance failed.
End Time : 06/29/2010 15:46:41
