VoIP and wireless connectivity
Aug 22nd, 2008
hello
i have two sites connected by wireless bridges 1300s (4kilometer)in the main office we deployed IP telephony system(cisco) i wanna use Ip phones in the remote site for 30 users can i connected all 30 phones from remote office by wireless to callmanager in the main office
thanks in advance
migilles Mon, 08/25/2008 - 15:46
At 24 mbps, you can get up to 27 simultaneous G.711 calls.
You have the option to use a different codec as well (i.e. G.729 or iLBC) when the RTP is traversing back to the main office via headquarters. For safe measures, would ensure to install SRST into that remote office as well with a few PSTN trunks to be on the safe side.
wesleyterry Tue, 11/25/2008 - 19:10
I know this may be a given, but I highly suggest enabling QOS on this connection. I'm guessing auto-qos is sufficient enough (I don't really know much about QOS).
I run the 729 codec as well.
