policy-map
Aug 22nd, 2008
hi,
does it make any difference if my class(es) are in different order.. say default class at the top in a policy and priority class at the bottom.. Will it require extra processing ..
Hope I am clear..
Thx,
GP
Jon Marshall Fri, 08/22/2008 - 01:23
GP
The order of your classes within the policy-map is very important because once the traffic has been matched by a class then no futher processing of the policy-map occurs. So you must put your classes in the correct order to match the traffic as you want to.
Jon
Giuseppe Larosa Fri, 08/22/2008 - 01:23
Hello Gaurav,
it makes the same difference as mixing the order of an ACL statements:
you can have traffic matching the wrong class.
I would recommend to have the classes in the right order for this reason before dealing with performance issues.
Hope to help
Giuseppe
