Aug 22nd, 2008
Based on vast experience can the experts recommend a syslog server to get logs from ASA and Routers.
Option 1 ===>> FREE
Option II ===>> Purchase
Overall Rating: 5 (1 ratings)
Amin Shaikh Fri, 08/22/2008 - 02:38
Forgot to mention I am looking for Windows OS.
Andrea I didnt get what u mean CCO u will find??
Damon Cassell Mon, 08/25/2008 - 09:50
My suggestion would be syslog-ng by Balabit.
There is both a free, and a commercially supported version.
Very easy to set up on Linux, and extremely flexible configuration options. Takes a few minutes to get used to the configuration syntax but it's really quite simple.
syslog-ng supports TCP syslog streams, which the ASA also happens to support, and this is a big bonus.
