Unity Message - Storage Limit is Full.
Answered Question
Aug 22nd, 2008
Recently we implemented Storage Limits in Exchange for all staff. Since then if anyone has exceeded their limits, they are prompted when they access their voicemail that they sotage linit is full. I am going to change the following in the attachments below to disable.
Is there anything else I should check.
Thanks a million.
Anthony.
Overall Rating: 5 (1 ratings)
Anthony O'Reilly Fri, 08/22/2008 - 05:10
I have made these two changes and staff are still getting this message "Hello, Your inbox is almost full"
The Version of Unity is: Cisco Unity 4.0 Build 4.0(5)
Any help will be much appreciated.
Anthony.
Correct Answer
Rob Huffman Fri, 08/22/2008 - 05:27
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Anthony O'Reilly Mon, 08/25/2008 - 02:31
Hi Rob,
Thanks a million for this, I used the registry key and this worked. I have to disable the disable funtion.
Thanks Again
Anthony.
Rob Huffman Mon, 08/25/2008 - 04:32
  • Hall of Fame,
    Founding Member
Hi Anthony,
You are most welcome :) I'ts always nice when you get an answer straight from those two gurus!
Take care,
Rob
