SMTP traffic with ASA 5510
Aug 22nd, 2008
I am wondering if the SMTP (port 25) is being blocked by default on the ASA 5510 Firewall. The reason I am asking is that when one of my exchange server tried to forward emails to the exchange inside the ASA 5510, the connections will always be dropped. I tried the packet tracer and it always say that the packet was dropped and the access rules that dropped it is the Implicit IP deny all rule.
I had performed a NAT on the 5510 for the exchange server and still the traffic does not comes in for Port 25 only. Specific rules had also been added to allow TCP/25 through but still the same problem. I wonder if there is an "inspection" on SMTP/25 which caused the problem? If not, how can I overcome this problem so that connections between the two exchange servers will talk to one another?
Many thanks for any suggestions,
Tan
Marwan ALshawi Fri, 08/22/2008 - 06:15
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
through the reason u got looks like packet filtering issue
could u please post ur config here
tanziweigca Fri, 08/22/2008 - 06:33
Hi Marwanshawi,
Many thanks for your reply.
Attached please find the detailed config of the ASA. Please take note of the server SGPCRS02 which is the server in question. I can ping it from outside but still traffic to Exchange keeps reflecting connection drop.
Tan
Marwan ALshawi Fri, 08/22/2008 - 07:18
is this one u have problem with
name 116.x.x.121 SGPCRS02-EXT description Exchange server for PO
is the internal server in the PO interface?
if yes
this line is good
static (PO,Outside) SGPCRS02-EXT SGPCRS02-INT netmask 255.255.255.255
but u need to add an ACL to permit smtp
like
access-list 100 permit tcp any host SGPCRS02-EXT eq 25
and shoud be applied in the indound direction on the outside interface
i think u have a poblem with ur ACLs
just check it and let me know
good luck
tanziweigca Fri, 08/22/2008 - 21:31
Had added the followings to the config but still the same problem.
access-list outside_access_in extended permit tcp any host SGPCRS02-EXT eq 25
access-list PO_access_in extended permit tcp host SGPCRS02-INT eq 25
policy-map asa_global_fw_policy
class inspection_default
inspect ftp
inspect icmp
inspect smtp
The traffic from external SMTP to Internal is still blocked. Can you assist?
Marwan ALshawi Fri, 08/22/2008 - 23:11
first u dont need this line
as long as u r using the external IP with static nat
dont forget
access-group outside_access_in in interface outside
secondly
try to disable smtp and esmtp instpection from
because sometimes they make problems
and let me know
good luck
Premdeep Banga Sat, 08/23/2008 - 12:46
  • Gold, 750 points or more
Are you trying to send the mails from outside to inside ?
The I think you should also have this in your inside inbound access-list
access-list PO_access_in permit tcy host SGPCRS02-INT eq 25 any
Prem
Marwan ALshawi Sat, 08/23/2008 - 17:45
i agree with Prem
because as i mentioned in my first post the problem with packet filtiring and especially with implicit deny ACL entry
so try access-list PO_access_in permit tcy host SGPCRS02-INT eq 25 any
and make sure of the inbound ACL on the outside interface aswel
Premdeep Banga Sun, 08/24/2008 - 06:03
But there is one more thing that I want to point here, If what I think is happening, then because we have allowed the traffic on outside access-list,
The firewall should add a session entry for the connection, and the returning traffic/packet should bypasses the many lookups associated with a new connection. :P
but anyways try "access-list PO_access_in permit tcy host SGPCRS02-INT eq 25 any"
What would really help you in understanding in what is happening is syslogs.
logging on
logging host
logging mon 7 (to troubleshoot this issue)
Or you can collect the logs from console too,
logging on
logging con 7
And then try to do what you are doing and share the logs.
turning logging off,
no logg on
no logg con 7
Prem
